1JZ scheme HELP!!
Which scheme do you think looks best ?
  • Total voters
    33
  • Poll closed .
alloyguitar
it's legal, i swear...
knoxville, tennessee
5l_eater;1275091 said:
Quick question...
if i pant my intake will it hold in heat ? and if so enough to worry about
also if i get polished is it a pain to keep looking fresh ?
...unless you use a product called Zoopseal (or similar) to seal it, it's going to be a pain in the ass to keep shiny.
For a car that gets driven quite regularly (I'm guessing yours does) I always feel that black is a safe way to go because it's easy to clean up and doesn't take a lot of maintenance.
As far as your intake holding in heat, I'm not positive, but I think that the differences in temps would be negligible.
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
I vote polish everything. The valve covers will take atleast 10-12 hours to do by hand without power tools. It's well worth the time though because the end result is amazing looking and the heat is removed faster. See the last couple pages of my build thread to see my polished valve covers.
Adam
Suprizim TT
200
Los Angeles
black it out.................. a lot of people have already polish the engine in every way. Do something different black it out and make it look unique.:evil2:
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
If you use a high heat paint it should hold up fine. A lot of people just use regular primer and paint on the VC's and it works fine.
5l_eater
I LIVE FOR THIS SHIT !
Jan 17, 2007
258
Maryland
no im talking about the heat issue with the Intake ...
honestabe
Happy as hell :D
Jan 15, 2006
3,713
5l_eater;1275219 said:
yea so you only used 400 , 600 , and 2000 ???
That's right, the 400 did most of the work. I really should have picked up some 1000 too, but oh well. Getting these 4 sizes will help get rid of all the divets while minimizing the removal of material. Also, make sure you use a sanding sponge. Never sand with a bare hand. You'll leave lines if you do.
5l_eater
Jan 17, 2007
258
Maryland
WhtMa71;1275255 said:
The intake shouldn't get much hotter than the valve covers.
Really hmmm im thinking polished valve covers with black intake manifold possilby and black turbo pipes ..well see its still up in the air
Zer0DeGreeZ
287
N. KY
What I'll Be Doing;
Valve Covers: Polished
Spark Plug Cover: Black Gloss
Cam Gear Cover: Black Gloss
FFIM: Polished
Exhaust Manifold: Ceramic Coated
Turbos: Polished
Turbo Piping: Polished
Lines: Steel Braided
Hoses: Carbon Looking Weave Hose Wrap
Spark Plug Wires: Black
Engine Block: Left Like New Aluminum
Engine Head: Left Like New Aluminum
Water Pump (Etc.): Polished
For me personally this presents a stock appearance but a very appealing stock appearance. It will be very clean with the wiring harness hidden and tucked through the frame rails. Battery and Fuse box relocated. Clean matching glossy engine bay with smooth fabrication for a clean appearance. Both turbos and Intake Manifold facing forward, with (hopefully) side mounted IC's to keep hidden from wandering eyes.
Opinions?
Zer0
5l_eater
Jan 17, 2007
258
Maryland
Zer0DeGreeZ;1275611 said:
What I'll Be Doing;
FFIM: Polished
Turbos: Polished
Opinions?
Zer0
yea ive already done my spark plug cover and cam cover black ... dont plan on touching exhaust manifold going single turbo ,valve covers polished seem to be very popular i like but also wont to be different ...but sound like its going to look good bro
Zer0DeGreeZ
287
N. KY
Thanks man. I'm not going to tune the 1 JZ-GTE i'm putting in this car. Just gonna be my daily putter that can kick but if it wants to. But i'm gona do the exact same thing with another supra the exact same color but i'll tune that 1JZ-GTE when i get to that point.
I just sort of have a thing for a clean stock car, but if I have two of the same I might as well toy with the second one right? lol.
Zer0
5l_eater
Jan 17, 2007
258
Maryland
yea deff plus if someone tlakn shit show them under the hood of ur dd 1jz set up a race for money then go home switch whoop dat ass lol
