Got a problem with my 1jz here.
I did a single swap a while ago, and everything was fine, put a wideband in, adjusted the AFR and it was pretty good (around 10.5-10.9 WOT), car ran fine, except it would cut out/sputter at WOT around 5K.
Anyway, about 2 weeks ago, it started to go lean, I'm talking 14.5-15.1 at low throttle and about the same at WOT. Tried adjusting it with SAFC 2 but it would not change a thing. Figured my injectors are starting to die on me. So I got a set of used 440's a week ago, put them in the other night. Started it this morning... took a while. and there is no change in AFR. it runs pretty shi**y I managed to get 13.8 at WOT by doing ~+40-50% on SAFC 2.
Also checked my FP, and set it at 50PSI with vac off...
Can't think of anything else at this point...
Mods are T-61, FMIC, intank walbro 255 (less than 1k on it), brand new fuel filter, 440's, SAFC 2, AVCR, AFPR, AEM UEGO, Blitz ECU (got STEALTH ecu as well, might try swapping them in case blitz is messed up), 12v Mod+ no fuel pump resistor.
Any ideas?
Also, I checked the codes and got 21 (O2 is unplugged) and 31. Have no idea what code 31 means on 1jz, since there is no AFM, or am I wrong?
Also, its kinda weird but in sensor selec on SAFC 2 I have it running off of hotwire, not pressure (MAP). If I do switch it to MAP, it runs like crap, even back when it used to get good AFRs. My guess is that the person that did install before I got the car messed it up... don't know if that means anything.
Thanks for any help.
Any ideas?
