Im currently using NGK bcpr7es 6282's and I have them gapped to .20 and im still blowing spark out. Should i try to gap them lower? these plugs not good? or my coilpacks are going out?
Supra-Man18;1548418 said:Possibly weak coils.. Wen i changed my plugs a few months back they were at .038 !!! and i was Very surprised i had no blowout !? i Went n did some research to find that my coils were in Excellent condition ! check yours out
92TealSupra;1548335 said:Any of your coils cracked? Also did you shrink warp them, that can help with these considering their age.
IJ.;1548327 said:What RPM is the stumble at?
lol, ~380whp maxed, but if you haven't checked you could be going lean.kamikazemkiii;1548423 said:Around 4000+ When your supposed to be in boost, How much hp does the stock fuel system support?
te72;1549874 said:You might do what I did and go with BKR5E, gapped at ~.028. Did that, fixed my stumbling issue after installing y-pipe completely.
TripleC;1549992 said:I second this suggestion, Regap to .028 that is what i did and it cured the problem
kamikazemkiii;1550281 said:I tried adding more fuel and still breaking up, wish their was a dyno that was near that i could hop on and see wassup with the fuel pressre when i get into boost. IJ you said the TT fuel pumps have a 60psi relief valve?
