1JZ Pistons
dinhnerz
52
Cali
Does Titan sell the 1jz piston rings alone or do they sell them with the pistons itself as a set?
I'm also in desperate need of piston rings.
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
dinhnerz;975855 said:
Does Titan sell the 1jz pistons alone or do they sell them with the pistons itself?
Yes they do.
Panchira!
Cressida+1jz+GKT550= :)
Jan 3, 2008
50
black hole
are they stock rings or for forged pistons? whats sean's screen name?
sent the block out on sat with aaron.....hopefully the block is 100% a.ok! if not i dont know what ill do.....
Jostar
May 21, 2007
746
Chicago
For the forge pistons & his screen name is 2jzmkiii, They even sell rods too for the 1jz, I just finish byuing something for my JZA70 :evil2:
Jostar
May 21, 2007
746
Chicago
dinhnerz;978628 said:
I just got an email back from Sean today. They don't have any stock piston rings.... :cry:
That sux buddy, Well try the MR2 3SGTE motor piston rings, I hear there the same.
525gte
450
hoquiam
So I dug up this old ass thread.. and I am about to order pistons. And just want to be clear
2j gte pistons can be run in a 1j stock rod. Correct?
And same goes for if I want to order a cp 2j piston in a 9:1 ratio. I just want to be clear that when I call cp pistons to get my 2j pistons I can put them in my 1j
Sorry for digging up a relic. But its 2 am. I am tired and this is the 1st thread I found on this subject
Turbo Habanero
4,229
Tucson,AZ
Why not just call cp and ask for 1jz 9:1 pistons? Or call Aaron at driftmotion and he can do it for you.
I'm running CP 9:1 pistons in my 1jz
525gte
450
hoquiam
I am going to do that I just like to look up all the part numbers and info 1st . From I I found it is cp. Number sc7472 86.5mm 9:1
525gte
450
hoquiam
bought my pistons today got a screaming deal on them from titan motor sports off of ebay for 690$.
now i go tto spend the day googling how much torq the stock rods can hold:0 it never ends lol
525gte
450
hoquiam
MK3Hitman21;1912849 said:
so you can use 2jzge pistons on 1jz rods?
I belive so just have to get the right compression. The pistions I ordered about make 10 to1 iirc on a 2j. And 9:1 on a 1j due to the stroke differance
MK3Hitman21
92
CALIFORNIA
stock comp on 2jzge is 10 to 1, stock comp on a 1jzgte is 8 5 to 1, so i like higher comp ratings. so maybe comp would round 9 to 1 in a 1jz with 2jzge pistons
525gte
450
hoquiam
Googgle it up. I came up with cp part number sc7472. And that will get get 86.5mm9:1. Its the same as 10:1 part number for the 2j. That's tahken off cp web site
525gte
450
hoquiam
MK3Hitman21;1913024 said:
yea cause forged oem 2jzge pistons are way cheaper than cp piston. i can go to a engine dismantler and get a 2jzge block hella cheap
Are you sure oem are forged ?. I don't belive they are. If they were no one would ever replace them
