OK guys here is my situation-
I have a 1jz swapped into a Conquest - The 1jz is out of a Chaser with Chaser ecu- it came with the engine harness - It is typical for the ecu to be missing 2 ecu plugs- no problem I got those - I dont have the relay but I have the ecu hooked up as follows
batt 12v
IGNSW swithed 12v
+batt switched 12v
+batt1 switched 12v....this should bypass the main relay issue right?
I have found that the igniter/coils and injectors power is on another plug (big black with orange strip) I have these also to a switched 12v
What else am I missing as the car still wont start?
I have read that there is another small black/orange wire that needs 12v but I dont have this wire on any of the plugs-
this is what is left on the plug
2 small black with white strip
1 big tan or brown
1 small green
1 small violet
1 small white
1 small black
1 small blue with pink strip
1 black with pinkish red
Any help would be much appreciated.
Thanks
batt 12v
IGNSW swithed 12v
+batt switched 12v
1 big tan or brown
1 small green
1 small violet
1 small white
1 small black
Thanks
