Hi guys,
My 1JZ is having the misfiring under boost problem. I've been searching and I've checked the usual culprits and I have some concerns
1) The cam/crank sensors resistance was in spec but both cam sensors had some oil in them.
2) 4/6 of my coil pack connectors were busted on the inside so I've ordered a new set, they still plug in good but there are no locking tabs and some of the pins are pushed back slightly. The coil packs themselves are in good shape with no cracks whatsoever
3) I got the map sensor with my engine and the seller had glued on another barb because he snapped the old one off. The engine runs and idles decent and when I unplug the Map the engine dies out so I think it is working but how can I test it to be sure.
4) I opened up my ECU to check for leaking caps and everything seemed good, no signs of leakage. Can the caps still be leaking without leaving visual evidence, and is there any way to test that this ECU is working properly?
5) I'm having issues with my cluster so I can't pull the codes. Is there any other way to check the codes.
If someone could please help me single out why my car is backfiring it would be greatly appreciated.
Thanks in advance.
Thanks in advance.
