Tomorrow I'm going to try to start running more test... I'll check IGF in the ignitor, also the crank and all other sensor to make sure they're communicating With the ecu
aphxero;1666165 said:I'm only gonna say IGF one more time. Check the wire. If the ecu doesnt see the confirmation IGF signal it doesn't turn on the injectors. Seriously check continuity from the igniter to the ecu. If it's good check for a pulse on it. No pulse is probably bad igniter or possibly ecu but I seriously doubt it. I've dealt with this numerous times so I'm speaking from experience here. I'd be surprised if it's anything else.
If crank sensor wasnt functioning you'd get no spark period. period.
