Evilempire1.3JZ-GTE said:
It is a power steering line! The hydro fan system.
People dont realize that the hydro fan is a verry parasite design sucking hp away from the engine it is an extra power steering pump just pushing a remote fan thats all. Its complicated looks ugly takes up room and is heavy, takes away from your water pump also.
Use the alternator most of its over generated energy is filtered and regulated back to ground the left over unused energy. Just use that wasted energy thats allready potentialy there to run a e-fan.
more theory below lol.
"Its like inventing a perpetual design by having an electric motor hooked up to an electric generator and saying you just spin the electric motor 1 time manuely and it generates enough energy to spin the generator and then spin the motor more. Endless process."
The irony of this is only people that believe this above theory love hydrofans.
I dont claim to have invented the wheel but when you should be dring round tires on the road and see people use square ones saying extending the harness is better you would hope to try and save people and help them thats all no HATE here. I am not insecure about the past post of other people 6 months ago trying to bring them down and throw down hate and discourage good ideas like some is there something wrong with me? I think i know what it is you extended your harness and blew up a couple ecus doing it wrong or know people who are taking longer trying to tackle the harness extension and you believe people must go through hell like you did to do there swap that must be it.
I know you are all excited about learning about cars and stuff, and you want to help others, but slow your roll there cheif.
What most people REALLY don't understand is that added load on a alternator also causes the engine to work harder to turn the alternator.
The horsepower required to turn the alternator is dependent on the load on the alternator. Electric fans pull a lot of amperage, electric motors are not 100% efficient, and alternators are VERY inefficent (only around 50%). Your perpetual motion comment is nonsense.
The loses of an electric fan are comparable to the hydrofan pump. The hydrofan is also variable speed, so in fact, it requires LESS horsepower to turn it when the engine is cool then a fan that is on 100% then off, and the hydrofan can better regulate the engine temp. A hydrofan on full speed also has probably 3x the cooling capacity of a dual 11" electric fan setup. So basically, the hydrofan kicks ass over electric fans in all situations you motor will be subjected to. All the horsepower you think you are freeing up by using a electric fan is being consumed by the alternator, plus some. I would venture a guess that the hydrofan is at least 10% more efficent overall then electric fans.
The real irony here is that you offer a whole lot of advice as of late, but most of it is misguided, or sometimes (as in this case) complete
misinformation.
Here is some good reading on alternators and such:
http://www.svapowerproducts.com/html/how_much_hp_does_an_alternator.html
