droppin a 1jz in ur car practicly easy meaning with boltin it up and plugin all the sensors in??? because im bout to drop it in my car in a few days still gota get sum parts for my powersteeing pump and a/c compressor.......
Doward said:Without proper grammar and punctuation, I feel this swap has no chance of happening.
What year is your Supra?
high psi 1jz said:If you have an 89 you will need 2jz ac lines, throttle cable, its not a bolt in kit. You will have to extend the wiring harness, and if you don't have an 89 do a some more modifying.
AZN MK3 said:well i have a 87 supra and i know i have to get these custom motor mounts from bicperformance.com. so what else will i have to modify??? and i knw i have to extend sum wires i was wondering which one also??
AZN MK3 said:well i already bought the engine and the bellhousing from toyota.. i've been doing some research for quite some time and i've gotten all the nessesary parts i need im just wondering if theres anything else i'll have to worry bout when im dropping the engine in...
