1JZ: Guys with HKS DLI
ForcedInduction
125
Chicopee, MA
I need to upgrade my ignition system, but have a few questions.
Which HKS DLI do you guys use? Universal one?
And which one should I use? HKS DLI 2 or the original one?
Thanks for the help in advance.
SirLoki
129
Fullerton
you would need the DLI 1 unit, i would look for the newer generation one as it is a little more resistant to moisture; newer gens have the red and black logo. The DLI 2 unit is for cars that have direct ignitions and or internal igniters and coils. The 1jzgte and 2jzgte are separate coils and ignitor.
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
I have one & i have no idea which one i have..... I know it's wired into my AEM.... I think Sound Performace used the MKIV application.
SirLoki
129
Fullerton
ForcedInduction;1097534 said:
Are you sure? I've been looking at some sites that sell Supra parts and they have DLI II up for Supras...
yes because on a 1jzgte the ignitor is a separate unit. Then the coil packs are on engine. DLI 2 is for cars like the mazda rx8 and subaru wrx.
heres HKS own site:
http://www.hksusa.com/products/?id=840
no application for DLI 2 Supra with 1jzgte or 2jzgte
agentAndy
xatracing.com
Oct 27, 2005
29
Sarasota
its just a matter of when the coil fires there is too much resistence in the plug due to the thicker atmospheare in the combustion chamber, and the stock ignitor and coils cannot overcome the added load.
I have had old coils that do the same thing. You might want to do new coilpacks and a dli to solve the entire problem. I have a new set of coils fyi:icon_bigg
agentAndy
xatracing.com
Oct 27, 2005
29
Sarasota
try using ngk bkr7es
if you have new coils you should not have this problem.
check cam sensors too for oil in the plug(bad on 1jzs)
and dont run irridiums.
