1JZ-GTE VVTi BOV Mod
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
That I understand, especially at stock boost levels; but you'll find them on big, fancy, aftermarket turbos as well. Even the EFR series uses them, though maybe because they go for the idea of "here's half of what you need with a turbo kit, built right into the turbo."
te72
Classifieds Moderator
6,610
7
WHYoming
That was a good thread on Turbo Miata, but I'm actually having the opposite problem. Too much boost with a boost controller (even on the minimum setting), but without it, I only get maybe 12psi, 13psi tops.
I'm wondering if a slight restriction somewhere might not be in order...
