1JZ-GTE Short Circuit - Where should I look first?
Spaniard
524
La pearla PR
My car would not turn on today. I would put the key in and turn it for a start, but even the dash lights or anything wouldnt turn on. I try to put on the flashers and they wont even turn on either. I think I have a short somewhere, but can put my finger on it. I did see that my EA2 connection was connected very loosely and it fell off when I was checking it's connectivity.
Any places a should first look?
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Check the EFI fuse. If you are not getting dash lights, it could be only the wiring between the fusebox, the starter and the ECU, or the ECU itself.
Spaniard
524
La pearla PR
battery is not dead, this has been confirmed. also, i noticed that when ever i connect the battery the positive side terminal heats up, like as if it's shorting out. EFI fuse and ALL fuses are not broken.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
the only time ive seen that happen is when they tried putting the battery backwords but it would blow your main fuse to boot.
JonoTurbo
Going for broke
CT
If all your fuses and fusible links are good, chances are it's either the main positive wire to the cabin at the battery or the circuit breaker in the drivers kickpanel. I'm betting on the wire at the battery since I've had lots of problems with the connection there.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i'd check for a break or cut in the main battery positive wire. and all grounds on the motor and chassis
Freshmaker
396
Oconomowoc, Wi
On my old 7m supra, I had an internal break in the smaller positive lead coming off the battery. I found it by opening my door with the keys in and moving the smaller wire around. Once I heard a beep, I knew I had found where the break was.
Spaniard
524
La pearla PR
Okay guys, I got a lot of hints from people and Dr. Tweak really helped me. That guy really know his electrical shit. It was a power wire running off the starter that capped-off but the cap fell off and kept touching the body of the car and would short out the system. The EA2 connector also had two bad wires that wouldnt light up any of the dash or the car at all! Everyone thank you.
