suprahero said:What's wrong with the hydro fan? I hadn't planned on changing to an electric fan. Do you know something about it that I need to know?
Turbo 7M said:yes i agree with annoboyingr clutch, timing belt, front and rear main seals, radiator, and i would say decide weather you want to keep your hydro fan or you want electric fans, and if you go electric you would also want to change your water pump to a 2jz one. i strongly recommend changing those parts too because you will endup changing them out later on most likely. speaking from what i've seen and learned.
suprahero said:This is why I asked.................:dunno:
