1jz gone... what to do???
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
AZN MK3;976635 said:
ok i've done a compression test and all of the cylinders come out to be at 180psi's except for the 5th one... its like 4psi's lower so that should be fine right??? as far as the coils anybody selling a set or if not is there a way i could wire up the 7mgte coil pack on the 1j? if so could anybody give me a diagram of how to wire it up??
compression is fine... check ebay just saw one last few days it might still be in auction.
aren't you glad u did a compression test :)
tsuper92
supra addict
Apr 7, 2005
1,376
mass
2j coil's are $60 each at the dealer.how many you need?i might be able to dig up a couple.
