1JZ gauges....
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Im swappin the 1J into my 87, and im not sure which gauges to get....
I'm thinkin "Boost", "Oil Temp", and a Tach!
Also will the MA70 temp gauge work with the 1J???
:1zhelp:
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
yes but you need the adapter. You can get it through DM
:1zhelp:
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i have a 1J in my 88
tach water temp all work
oil pressure doesn't but all i need is the adapter and 7M oil pressure sender and its good
you dont need to swap the tach out
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Im not doing the front clip... I just bought the motor, tranni, harness, ECU...
What adapter?.... does it make the 1J harness hook up to the MA70 gauges???
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
But the 7M reds at about 6.5K and the 1J reds at 7.5K... Right???
Does the 1J work off the same temp. as the 7M... I mean it doesn't run hotter or have a different overheating point???
The Reaper
Jan 10, 2006
1,909
Florida
who cares you'll just be red lining according to the 7M tach
if you now it revs to 7500 then shift before then do you really need a red painted surface on yur tach to know when to shift???
if yur on stock twins and stock cams you have no need to rev above 6800 anyways as it makes NO power there
and the temp gauge is the same
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
HellsLegion said:
Not oil pressure.
Try to get a 1JZ tach, it looks best
So, you can just swap out the tach part of your gauges???
Where would i get a 1J tach?
Thank you guy's So much this is helping me out a lot!!!
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Yeah! Direct fit! I would look on ebay, Or look at for sale sections, They pop up very regularly. Ask around with people with clips!
The Reaper
Jan 10, 2006
1,909
Florida
heres the pic
heres the info
"This adaptor is to use a 7m oil pressure sender on a 1jz block in order for the stock mk3 oil pressure gauge in the dash to work. Many people are running their 1jz mk3 with no oil pressure gauge. This is because the 7m sender will not fit behind the ac pump on the 1jz. We came up with this and use it on our 1jz swaps. Just screw it into the block, screw the 7m oil pressure sender into it. Hook the wire that was for the 1jz oil pressure switch to the 7m sender and you are done."
and the price is 20 bucks
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Yeah i didnt really think about the redline of the tach... It would matter at all... Like Reaper said, If i know it reds at 7500, then shift around 6800!
Thanks... So back to the main Q:
I just need "Boost" then???? I have a two pod piller do dad... What other gauge would come in handy??? NOS maybe??? <J/K:biglaugh:
