1jz Fuel Setup
OneJArpus
2,798
I have a Walbro that i am going to install. Other then that, thats it stock fuel. When i pulled the 7M the J tube was still in the engine bay. Do i need to hook that up to the 1J? I'd like to get some pics of people with stock fuel lines hooked up so i know how i can do it. Thanks
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
you bolt the fuel line to the fuel pulsation dampener. if its at the j tube i would start taking some pieces off hehe
tlo86
Jul 24, 2005
3,914
Colorado
TaSe;1024983 said:
lol ok, so disconnect the line from the J tube n put it on the stock 1j dampener and thats it right?
if i remember right , the fuel line goes to the FPD, then to the j tube. (doublechecked and this is right, the FPD bolts onto the mount before the j tube on the 87' , should be about the same on the later years too just bolt on location is different. didnt spend much time with my 7m sad to say but where you bolt it on will look just like where you bolt it on to the 1jz, its real easy once you have the engine :):))
