1jz fuel pump
1wickedA70
332
Queens
1jz swap in my 87 hardtop is still breakin up under boost this time instead of breakin up at 2500 it breaks up at 4500-5000 since i gaped the plugs to .025, i have a stock NA fuel pump, will i have to upgrade my fuel pump to a 255? my mods are 3 inch exhuast, FMIC, hard pipes, intake, boosting at 12psi.... im pretty sure one of the reasons the car is breaking up under boost is because the lack of fuel its getting into the motor, also i think i have to gap my plugs down a lil more to .022, let me knw wut u guys think i should do?
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
upgrade the pump most definitely
and you shouldnt need to gap your plugs that tight, im running .028" gap on 6097's without any problems
pbasil1
Fully built 1JZ project
Jan 30, 2008
402
Huntsville,AL
Just get a walbro 255. They arent expensive, and are a direct bolt in. Driftmotion has them for just over $100.
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
1wickedA70;1309029 said:
would the fuel pump from the sc300 work..my boy has one parting out
Jesus christ man!!! GEt a walbro, How can you swap a 1j & not buy a 100bux pump....:3d_frown:
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
If I didn't have the time to install or purchase an aftermarket pump, i.e. a walbro, what would a GE pump support?
I'm putting the 1jz into my 87 n/a and I won't be able to put an aftermarket pump due to certain circumstances. I just want to get it running, work out the kinks, and park it for the summer.
I think the GE pump will work for 370cc injectors as I'll be mostly stock. Now big power upgrades, 3" exhaust (incl. y-pipe and back), 2.5" hardpipes and aluminum FMIC, nothing else I can think of to do with the engine.
However, I may dyno it and/or take it to the track for a pass or two before I lock her up. I want to have a LITTLE fun before I store her. The dyno will be to get a baseline for future mods.
Basically, my question is would I run into any problems using this pump for a few days, with the possibility or being driven hard for an hour or two maybe.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
arent sc300's fuel pumps the same as the 2jzgte cars? id say thats better money spent if so.
Guyana00
Apr 18, 2007
1,208
Brampton, ON
I don't have a definite answer of the ge's pump capabilities. I'm still assuming because of the similar injector size, I've searched it and haven't found something to make me not wonder. Also don't know if the sc300 pumps are the same physically and/or capacity-wise.
Guyana00
Apr 18, 2007
1,208
Brampton, ON
I'm wondering if my pump will hold up under boost, stock engine. I wouldn't be able to put in a walbro for a few weeks so I need to know. Thanks.
makaveli913
1jz and lovin it
Nov 20, 2007
135
Pueblo Co
i daily drive my 1j with a ge pump. no noticable fuel problems for a year!! i also have a mines ecu idk if that has anything to do with it. It does seem to run a lil rich(gassy exhaust). boost reaches 13-14psi no problem. i have no afpr or boost control with basic mods..exh int hard pipes
Guyana00
Apr 18, 2007
1,208
Brampton, ON
Does anyone run an Aristo pump in their mk3? does anyone know wat they flow, same at the mkiv?
Someone is selling an Aristo pump almost new for $25 local and wanted to know what it flows and if anyone runs one, thanks.
