I cant seem to get my 1jz to rev past about 2500 rpm before it cuts out and goes lean, i have no idea what to check codes. They guy who did the swap didnt wire in diagnostics... I have already replaced the fuel pump. Tested new fuel pump and the fuel system, holds pressure so im not sure what to check now. Could my afpr be giving me this problem? I have noticed that when i wiggle the soft line thats supplies the fuel that the afpr will either loose or gain about 5lbs of fuel pressure. Is that normal or could that be giving me my problem?
I am using the same map that the car has running on. Also tried adding fuel and that hasn't solved the problem either.
Mods:
61mm turbo
550cc injectors
TT fuel pump
Aeromotive afpr
Stinger ems
Thanks, Marcus
Mods:
61mm turbo
550cc injectors
TT fuel pump
Aeromotive afpr
Stinger ems
Thanks, Marcus
