hey guys been having a problem with my one j. i just installed a set of mkiv 550's and an afpr kit from dirtmotion. the car idles fine and drives real good normal drivng but when i go wot it cuts out in the higher rpm. the first test drive it would cut out at like 5500, i lowered my fuel pressure and that seemed to help a little but still cutting out so i lowered it some more and i can get to about 6500 rpm now. but im getting down to like 20 psi fuel pressure. its it ok to keep lowering the pressure or is there something else i should check out? im on stock twins with intake exhuast and intercoller/hardpipes and now afpr/550's
