1JZ CODE 78 need some help
ANDR3AS
32
Toronto, Ontario, Canada
I just did a 1JZ GTE soarer into my 1988 supra turbo got a harness from tweaked. I hooked it all up the cranked very well but it didn't turn the fuel pump on. then I wired in a fuel pump relay kit with a switch so the pump turns on when I flip a switch but now I noticed that im getting a code 78(which is also what I had when the harness was controlling the fuel) which from what I know is a fuel pump code. will this cause the motor to crank catch for a couple seconds then die even when I have the switch on?
Thanks
NecroCyde
Lurk R
Calgary/Brooks, Alberta Canada
If its getting fuel, it should just be a warning code, not stop the car from running. Have you asked what Dr. Tweak what he says and why one of his harnesses throws a code and didnt run the pump? Are you sure your pump is good? May be time for a jza80 upgrade anyway.
