1jz clips help needed
User Name
JEDI MASTER!!!
Apr 1, 2007
victorville
hi hows it going fellas, i bought a full 1jz swap for my mk3, swap came with harness ecu motor ect. well i was looking at the harness and here in the picture u can see some grey clips, can anyone help me identify wat clips these are? i know the black clips go to the ignitor but idk where the greys go, ive tried searching for the answer but i honestly didnt know wat i was really looking for. thanks in advanced -eric clips.jpg
User Name
JEDI MASTER!!!
Apr 1, 2007
victorville
these plugs are attached right next to the ignitor plugs, but have no idea where they would go. no sensors or clips that mate to this, unless im missing a sensor somewhere
The little one looks like it goes to a noise filter thats usually attached to the igniter.
The big one I'm not sure. Could be for cruise control or something. Can look at the wire colors then look at the Ecu and body plugs and find the same color wire and use a ohm meter and see if you found the same wire as there is multiple of same color sometimes. If its on the Ecu plug look up pin outs and see where it goes. If its on body plugs it might not be used and could be pulled.
Maybe someone else will know as well.
f00g00
586
Kuwait
1jzharnessfuseboxb.jpgThe large one is the EA2 plug that connects to the JZA70 fuse box, the small one I'm not sure but mine had 12V switched power on one of the pins, but from the photo is also goes to the fuse box for the JZA70. I picked that photo up somewhere on the net when I did my swap.
