1JZ Buying Questions
Phyrx
20
Millbrook, AL
I am looking into buying a 1JZ and I found a motorset for 850.00 but it is automatic transmission.
My 7MGTE is r154 tranny so will I be able to use my transmission on the 1JZ? Also, What about my clutch? If I need the bellhousing, will the auto bellhousing work, or no?
Thanks
Mark
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
They are 100% identical (minus bell housing & flywheel) R154's
Or you can V160 6 speed that 1JZ but then you need around a 3.20 diff otherwise you have to launch in second gear making 6 speeds useless.
Also if its not a 3.20 with the V160 then you have no top end speed.
Evilempire1.3JZ-GTE
Jun 22, 2006
1,382
SoCal
mattjk said:
hey evil. can you get a V160 for $160, and the 3.20 diff for $3.20???
I'm interested in buying!!!1
Not unless you know someone who will steal you an mkiv for that cost. If you do im in!:biglaugh:
Lol all my naboring crack heads in this town are in jail.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
the 1JZ bell housing can be had at Champion Toyota for $300. Flywheel is $223 from them as well. Any 7M clutch kit will work with the 1JZ bellhousing/flywheel with the R154.
The auto ECU WILL also work with a 5-speed.
