1jz bottom end knocking
BigSupe
97
England
I started my car up earlier whilst it was on a set of axle stands and the bottom end started to knock noticably. I jacked it up and removed the stands re-started it and the knocking stopped.
Why did this happen? The stands aren't very tall and the oil is full on the dipstick and there was oil pressure as the light was extinguished
Could this be the start of the end for it?
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
MMMmmmmm maybe... I had similar sound coming from my bottom end in winter then summer came around boom rodknock..
BigSupe
97
England
Great news! What oil are you using? Is 10w40 ok
I changed my 7m cos it got rod knock and was under the impression the 1jz was bullet proof
What would be the best route now as I have a gt3076r and about 420bhp, should I just carry on using the engine or is there something I can do to prevent it getting worse
tsuper92
supra addict
Apr 7, 2005
1,376
mass
was it sitting for a while before you started it?maybe you should have cranked it with the efi fuse pulled,help get some oil flowing.
BigSupe
97
England
It was sat for a few weeks so I pulled the fuse and cranked until the pressure light was extinguished, it was definately coming from the sump pan weirdly though with a small bit of throttle it went only knocking at idle, after about 15secs I shut it down and lowered it off the stands and it was fine
Took it for a 20mile drive with no problems, what's the next step to take?
I'd say ten hail mary's and sacrifice a virgin just to be on the safe side.
Other than that, I don't really know. If it's not knocking, I'd just make sure I kept some good 5w 30 Redline in it and also make sure you have a quart extra in there. I make sure I'm at least a half quart to a full quart over my full mark.
Gritz
155
nc
general rule of thumbs say that running a quart over the full amount puts extra pressure on the rear main seal, causing it to fail over time...but what do i know, i come from a family of 8v lovers!!
BigSupe
97
England
Is it worth changing the shells at this point or just use it until it goes bang?
Obviously the oil is between the shell and crank journal for lubrication does it also take up some of the tolerance, I'm trying to get my head round why it was knocking. If there was no oil for some reason would that cause it to knock instantly?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Yes. If you listen very carefully when you first start engines up you can hear it knock for a couple seconds until it gains oil pressure
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
not that it matters to much now but that stock light in the dash for the oil is only a oil level light so if the oil level is low it will light up.
Much better to See what the actual oil pressure is.
Was there an aftermarket clutch on there? Skimmed through the thread and did not see anything about that. Don't think it's a real major problem but could be contributing to the knock at fist.
You sure it was a knock though?
Seriously do you even have the faintest clue what you're talking about?
This is the tech section if you don't know don't post...:nono:
How the hell does 1qt extra put "pressure" on anything?
(hint the rear main ISN'T pressurised in these engings meaning the only pressure it will ever see is crankcase pressure)
BigSupe
97
England
I have a 6puck clutch, pressure plate and flywheel from driftmotion. It was definately a deep constant knocking
The engine must have been getting oil as when cranking the speed got slower when the pressure light extinguished, suggesting to me that the pump was picking up thick cold oil
Just trying to save money/time if it's better to remedy this now, or is it a case don't fix what ain't broke?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
why are you using 10w40?
i used 5w30 pennzoil platinum. 0w30 castrol syntech. and 5w30 amsoil
bullet proof? not if you are a moron :( i have seen 2jz's blow headgaskets and get rodknock without performance mods it was purely the owners fault
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
I think he is trying to imply that oil would be high enough that the main seal would literally be holding the oil level rather than just stopping splash oil from leaving
grimreaper
2,180
Dallas
juhanis;1221620 said:
i learned this lesson last week... good thing my car is running again.
solution?
what pressure plate? You have a clutch start switch override?
cold start knock is my guess. let the car sit for a few days and see if it does it again on start up.
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
I would bypass your pedal switch if you are running a higher pressure plate. The thrust washer might be wearing out (crank walk). 20 yr old bearings...10w40's are just fine.
BigSupe
97
England
We dont have to depress the clutch to start our engines over here, I have been told that all 1jz engines are noisy on initial start up
A guy on the mkiii supra website has said his had the same noise for 6 years
I notice thats theres quite a big thread on SF but I don't think anybody has found out what/why it happens
I will be keeping my fingers crossed and leaving for a week then starting it up again and see what happens
