1jz boost leak
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
The Reaper said:
you running 550's with no fuel controller? SAFC, EMANAGE, AEM???
if so then thats prolly your problem. the 1JZ runs pig F'in rich stock
and i answered your problem in the very beginning
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Not really. He has a fuel controller for the 550's and It was tuned a bit on the richer side on a dyno while this engine was in my car. since we put it his car - and nothing on the safc has changed settings or wiring wise we were wondering what could be causing the hesitation.
Boost leak was tested for, and nothing was found leaking.
I think the driving style and lack of time with this engine may be contributing to more questions for the owner :)
It does hesitate when stomped on , or boosting ( floored from the start)
Hesitates on the top end as well. We will put it on the dyno again to make sure the tuning is fine. Maybe his fuel pump/pressure is weaker?I don't know....we will figure it out though...
The Reaper
Jan 10, 2006
1,909
Florida
interesting
hesitation could also be something with a clogged fuel filter timing is probably being pulled?
sc250tt
twins @20 psi
Mar 22, 2007
10
florida
The Reaper said:
interesting
yup my 1j first 1j sc had the same problem and it turned out to be the fuel filter , too bad i found out too late and my engine started knocking on startup :nono:
