so i need some advice on a cooling issue. i've been driving my car around for about a month now usally at night. the car runs at ~185 untill i get on a a few times then pretty consistant 190-195. today i was driving on the highway and it was hot out about 92degrees. on the highway my car was up to 200 degrees then spiked to about 208. when i got home i shut off and looked for leaks but there was none. i turned her back on and the temp was at 230! but i had turned it off when it was at 200? anyways the cars temp fell quick after i turned it on but i noticed quite a bit of water returning to the overflow tank.
do you guys think i need a better fan?
what should the running temp be?
my radiator is a new godspeed all aluminum with water,water wetter and 15% coolant.
i have a large fan *in front* of the radiator.
new water pump, thermostat, rad hoses.
engine is stock at stock boost
thanks
thanks
