Now that Spring break is here, and I have some time, I've decided to post my first build thread. I've been on SM for a few years now, and the network is great, just met a few inspiring local SM members Nate, Ron, Tom, Duane, and a few others here in WA...
First off, I would like to introduce myself. My name is Josh and I am a student at the University of Washington. So, yes, of course this will be a budget build :3d_frown: I'm 20 and have been a gear head for most of my life. I've owned only Supras and 300zx's too many to count, but for now I have a z32, a couple Ma70's, and my first Honda! don't worry, its an '82 Nighthawk cb650! I like to drag and drift, and go on organized drives.
I've done numerous swaps and builds, nitrous, NA-Ts, worked with a wide range of cars, from Euros to Domestics but...
This will be my first 1J/MA70 and my first 7M/MK2 so I could use all the help I can get :1zhelp:
I guess I'll start by adding a parts list that I have gathered thus far (ascending according to time of purchase)...
Parts gathered so far-
(all prices include shipping)
1JZGTE Soarer Motorset - KWNate via SupraMania - $900.00
Motor Mount brackets - R n D Factory - $135.00
TRD 1JZ Flywheel -supraspeed98 via Ebay - $289.30
ACT 6 Puck Clutch - 935Motorsports - $163.29
Apexi Blow Off Valve - Supramania - $35.00
XS T3 tubular manifold + Wastegate - Starletgt via Supraforums - $175.78
1JZ Map sensor + connectors - B-rett via Supraforums - $90.00
Walbro 255lph Fuel Pump - Ebay - $98.00
Flex-a-lite Black Magic fan - Ebay - $50.00
Permacool oil filter relocation kit - Ebay - $40.00
Manifold Heat Wrap Black - HDM via Ebay - $12.00
Digital (EGT) Pyrometer - Auberins via Ebay - $69.99
GodSpeed Intercooler 29x9x3 - 06wrxsti via Ebay - $65.00
K&N 4 in. Air Filter - Summit Racing - $39.95
Redline MT-90 4qts. - Summit Racing - $47.55
Garrett T3/T4 Turbo 60-1 - Tim via Supramania - $525.00
JDM 2JZ 440cc Injectors - Bigmoss via Supraforums - $115.00
Tein Type HA Coilovers - Jarco via Ebay - $610.00
1JZ Bellhousing - Champion Toyota - $324.00
1JZ Flywheel Bolts - Champion Toyota - $39.76
2JZ Upper Radiator Hose - Champion Toyota - $10.56
2JZ Lower Radiator Hose - Champion Toyota - $11.04
2JZ Throttle Cable - Champion Toyota - $48.14
HKS BCD - Ebay - $40.00
Apexi SAFC-II - NWN - $150.00
Greddy Profec B-II Boost Controller - $150.00
2JZ pilot bearing - Schuck's - $15.67
Air Filter - Schuck's - $21.80
Hayden oil cooler (pwr steering) - Pep Boys - $30.40
3/8 inch hose + fittings - Western Fluids - $25.00
Clutch Slave Cylinder - Rodland Toyota - $85.00
Serpentine Belt (no AC) - Schuck's - $32.75
Various fluids, wiring, etc. ~$200.00
Still Working on -
FPR - ?
Hoses - ?
Turbo exhaust - ?
Oil lines - ?
and many many more...
Still Working on -
FPR - ?
Hoses - ?
Turbo exhaust - ?
Oil lines - ?
