not sure if this is the right section or not, but I have a cressida with a 1J, so I figured this was the spot?
so the car is 98% done.
the only 2% stopping it is the starting problem...
I have the battery on a charger all the time, and it has 12.something volts.
But I go to crank it, and the starter engages but doesn't crank the engine, like what usually happens when you have a dead battery.
the only way to start it is to jump it.
anyone have any comments or concerns on this?
battery is in the trunk and is an optima red top, if that helps any.
