Hey guys my 1J developed a coolant leak today, just looking for a little input.
I can pour water in the rad and it leaks out just as it sits. It is coming from behind the alternator somewhere. I removed it to try and see what is there but still cannot see the origin. With the alternator out of the way you can see water flowing out in a stream from above it. I am suspecting the water-pump, that sound like a possible culprit? I cant think of anything other than the headgasket that is in the general area.
If it is indeed the water-pump, what are my options? I know I can swap a 2j pump in but than I need a clutch fan and some other stuff... I would like to keep the hydro fan, unless it is crazy expensive to do so.
Ideas, opinions? I am sure it is the waterpump, there shouldn't be anything else leaking like that up there...
