O.k. with a fresh approach I went out for more testing
unit off ... climbs fast to 15 psi and hit cut
unit on with these settings
set...25%
set gain...20
gain.........0
warning ...12
limiter.......9%
cimbs fast to 13 then slowly crept to 15 in 3rd abd hit cut
held at 13 at WOT in 5th slight uphill grade
I then tried to lower it as much as possible with these
set.........5
set gain...1
gain.........0
warning.....10
limiter........5%
at these settings I boost to 13 slowed and again crept to 15 and hit cut in 3rd but will hold at 13 in 5th at WOT
I wonder if my y pipe , 3" downpipe, 3" exhaust. no cat, 24x12 x3" IC may have pushed my stock boost over the fuel cut mark ??? Any ideas ??
outside climate
20* c ( 68*f ) @ sea level
engine temp...180*
Cheers
Bruce
set...25%
set gain...20
gain.........0
warning ...12
limiter.......9%
set.........5
set gain...1
gain.........0
warning.....10
limiter........5%
outside climate
engine temp...180*
Cheers
Bruce
