Hi all !! I've just completed a 1J swap in my 82 MKII and i've been trying to set up my Greddy Profec B spec 2 controller . It's hooked up correctly ive rechecked several times . I set the warning for 13psi and the limiter at 20% and the set at 0 ( stock boost ) . My goals are to have a reliable 300hp range and not to exceed 13 psi in hopes of keeping my twins for a while. Well all that turned to shit when I got back this morning from a little spirited ride . I checked the peak boost and it reads 19.7 :aigo: .. OMG i'm going to blow my shit up !!!! So right away i'm thinkin stock ecu , stock injectors , map sensor ... I did feel a stumble comming out of 3rd once while heavy on the gas so I assumed that was probably the rev limiter but maybe it was fuel cut anyway the damn Profec should have done it's friggan job and kept me under 13 regardless .. I'm not sure what to do next and i'm hoping you guys can help. This is new tech for me so flame if you must but help if you can . Cheers
