1GZ-FE - My new project motor!
redrocco
QUADCAM
Feb 21, 2007
78
Rochester NY
As far as weight I had read some place online that the 1GZ is very close in weight to a 2jz-gte but untill I can get mine on a scale I don't have a true number. However after removeing all the parts that I do not need I would guess I will see at least a 30% reduction. As far as money goes I am trying to do this for as little as posable but I will NOT cut corners. I do my own fabrication which saves me lots of money and I will also try to sell all my uneeded parts to get back some of the cost of the engine. I will also be offering copys of parts I make for sale to people on this fourm as well as lextreme. For instance the billet 4140 tilton triple plate flywheel I am makeing for this swap will also work on a 1UZ as the crank snouts are the same. If I make 2 flywheels for myself and 4 or 5 extra and sell them for $150 - $200 the extra flywheels will pay for the rest of my clutch and not cost me anything out of pocket. Not trying to get rich just don't want to go broke. ; )
te72
Classifieds Moderator
6,611
7
WHYoming
Stuffing a v12 into a Mk3 Supra, and you don't want to go broke? :rofl:
Good luck with that sir. :)
destrux
1,183
10
PA
I'd love to hear one of these built up in NA form. 15:1 CR (run E85), custom cams (maybe JZ cams could fit?), head work, ITBs, and some well designed tubular manifolds. I'd bet 450whp could be attainable pretty easily, if not 500whp. I'm not sure what the stock rev limit is, or what the limiting factor there would be (rods, valvetrain, or what), but an 8000 rpm rev limit would sound sweet. Doing custom rods/pistons would mean you could play with improving the rod ratio too.
Oh the ideas.... I love projects like this, good luck.
supranz
55
Christchurch
Subscribed for sure. I'm looking to go down this path too so I wait for your solution to issues with bated breath. Best of luck!
redrocco
QUADCAM
Feb 21, 2007
78
Rochester NY
I have been working on getting the engine cleaned up over the last week or two and its starting to look nice. I have also found a very nice 89 MK3 shell about 5 hours away from me that I will be picking up on 3/24. After talking with some other 1GZ owners and reading posts on lextreme the 1GZ rods seam to be 10% to 15% beefier then the week 1uz rods. The week 1uz rods are good to 50HP each reliably so the 1GZ rods should be good for 50-60 HP each so 600HP to 720HP should be fine on the stock rods as there are 12 of them.
2012-03-18_01-27-28_570.jpg2012-03-18_01-27-49_101.jpg2012-03-18_01-28-04_708.jpg2012-03-18_01-28-17_679.jpg
89niner
120
warshingtonia
you sir, are a genius :) i just want to hear what it sounds like. very cool project btw, v12 vvt-i and boost = pure bliss. adding nitrous for further excitement?
supranz
55
Christchurch
Bit of an odd question, but did you get the accessories with the motor? I see you have the powersteer pump, but what alternator and A/C pump are you going to run? 7m ones with custom brackets?
redrocco
QUADCAM
Feb 21, 2007
78
Rochester NY
The engine came with all the accessories but I will only be using the alt and the PS pump. I will not need the ac pump or the hydro fan pump. I will how ever need to add a dry sump pump. I am also considering swapping out the belt driven water pump for a remote external electric unit as the water pump and thermostat housing are quite tall and mounted on the very front of the engine were there is the least amount of hood clearance. I will know more once the engine gets test fit and I see how much clearance there is.
te72
6,611
7
WHYoming
Kai;1818947 said:
One question - how the hell did you source it, and how much did it set you back?!
x2. In all my searching/shopping, I've never seen a Toyota engine bigger than a 6 cylinder...
te72
6,611
7
WHYoming
MightyAl;1819049 said:
The 2uz-fe is quite common.
Frain bart... completely forgot the volume engines used in pretty much every luxury car Toyota built for 15 years... 1uz just as common too. However, they only used this engine in one car.
Backlash2032;1819102 said:
Well this is just two 1JZs :D
Displacement wise, but I don't think it really shares much of anything else... I believe the OP posted the bore/stroke details earlier.
redrocco
QUADCAM
Feb 21, 2007
78
Rochester NY
Toyota has been making V8's since 1963 and also has made a V10 and V12. I had been looking for and researching the 1GZ for the last few years. After I finished my 1UZ swap I started looking into getting the V12. Took me over two years to find one for a good price. I eventually got lucky and found some one with one for sale 3 hours from my house for $3200. It has the same 6 bolt main setup as the 1uz, 4 bolts up from the bottom and 1 through each side. Lots of the design for the 1GZ V12 came from the 1UZ, they can even use the same flywheel. The 1UZ can be had for $600 or less and makes for a good engine and also good practice for the V12.
V8
1963 - V - OHV
1963-1967 - 2.6 L (2599 cc) V
1967-1973 - 3.0 L (2981 cc) 3V
1973-1983 - 3.4 L (3376 cc) 4V
1983-1998 - 4.0 L (3995 cc) 5V
1989 - UZ - DOHC
1989-2002 - 4.0 L (3969 cc) 1UZ
1998-2009 - 4.7 L (4663 cc) 2UZ
2000-2010 - 4.3 L (4300 cc) 3UZ
2006 - UR - DOHC
2006 - 4.6 L (4608 cc) 1UR
2007 - 5.0 L (4969 cc) 2UR
2007 - 5.7 L (5663 cc) 3UR
V10
2010 - LR - DOHC/VVT-i
2010 - 4.8 L (4805 cc) 1LR-GUE
V12
1997 - 5.0 L (4996 cc) 1GZ-FE
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
It's more like a neo aluminum block vvti 1J, per cylinder bank.. but it really shares zero in common as far as what I can tell.
Toyota needs to follow BMWs way and make a sleeved aluminum block 3.5L, turbo I6 (3JZ).
