Should be the same but if you're unsure hop over to www.toyodiy.com and check the part numbers
Sent from my 7 Trophy using Board Express
suprra_girl;1942715 said:Should be the same but if you're unsure hop over to www.toyodiy.com and check the part numbers
eizan1892;1944671 said:Just wondering guys if it is possible to put a R154 gear box on a 1g-gte??
martin p;1948064 said:If you can get an Adaptor plate made, as There isn't a R154 to 1G bellhousing As far as I know.
