Copy/paste from the Subaru forums because I'm lazy and didn't feel like retyping it all.
Hey fellas,
My girlfriend's best friend called me today. She's got a '99 Forester, 2.0L (?) It's not a 2.5L, I know that much. Here's the problem:
She says she left her lights on (I thought they shut off with the ignition?) and killed the battery. Her sister tried to jump the car, however, she hooked the jumper cables up backwards. In any case, she replaced the battery with a brand new one, it's all hooked up correctly.
Cables are clean, battery lugs are clean as a whistle, and for good measure I checked and cleaned all grounds I could find. The starter has 12v to it directly from the battery. Cable checks out ok. When you turn the key, nothing happens. Not even a click from the solenoid. I checked the solenoid wire, it has a constant 2.8v going to it. When the key is turned to start, it remains at 2.8v, it will not jump to 12v like I assume it should.
First thing I checked was the fusible link in the engine bay fuse block. It's still good, verified with an ohm meter. Every fuse in both the engine bay block and interior block are perfect, I verified via continuity check, not just visual inspection.
So, my question: Is there another fusible link that could have popped, thus killing power to the starter circuit? All the headlights, tails, interior, door buzzer, etc all work fine. But when the key is turned, nothing at all happens. The lights don't even dim, which makes me think that the starter is NOT the problem, because it should draw serious amperage if it's dead and seized up. Doesn't seem like it's getting any juice at all.
Anyone have an idea? I searched around but couldn't find anything on the subject. This is odd to me so I'm determined to figure it out. Usually the first thing to pop is the fusible link from my experience. Thanks in advance!
Edit: forgot to state that when the positive cable is hooked to the battery, and I connect the negative cable there are no sparks at all. As if the battery is not powering anything (though the lights all work as mentioned above) Odd...
cliffs:
Every fuse in engine bay and interior fuse box on driver's side is good. Verified with continuity check. Nothing happens when the key is turned. All lights work fine, and do not dim when key is turned.
Hey fellas,
cliffs:
