Update:
I tested the TPS resistance and it checked out per the TSRM. Now I'm going to check the CPS timing
DieselScout2;2090781 said:No codes right now.. The car is teasing me. It runs great for a second or two, then will return to the usual problems. I have tries unplugging the TPS and the lexus AFM(same as maf?). When plugging the afm back in the idle increases for a second, then dies down. Also, My temp gauge is not reading at all. On the thermostat housing the top sender has a wire connected to it, and if I'm not mistaken the sender right below it should have one as well, correct?
Mk3TargaJames;2090790 said:Yes. The top sends to the guage, lower to the ECU. ID CHECK TSRM resistances on both too. And if it's just bare wire ran through the loop, please do a favor for all people who care about connections, put a correctly sized connector on there, solder it and heatshrink ))))
DieselScout2;2090794 said:Yes, the wire to the top sender is bare and wrapped around the tip of the sending unit.. Will correct that. My next question is that there are two wires (see pic 2 of first gallery) near the CPS that are cut. Any idea which one goes to the sending unit? Or do the both attach to a plug?
ALSO, adjusted CPS timing, no dice. Set timing to 10 degrees and now the car idles even rougher..
DieselScout2;2090812 said:Car struggles to start and needs some throttle to keep idling. Once "warm" it idles OK. I will check out the connection at the sender and the sender itself. On the thermostat housing the only part disconnected is the A/C, which makes sense as the A/C does not have a belt on it currently. Everything else is connected, but I will start tracing wires.
Mk3TargaJames;2090822 said:I don't want to say that it's 100% CPS related but it sounds like it. My car also will crank 10-15 seconds when stone cold before it grabs ahold and starts. When it's warm it'll start up like a normal car. Have been putting it off as I have blowby from the compressor side seals being bad. I'd say keep toying with the CPS, there should be a thread somewhere about how to time and adjust said component.
DieselScout2;2090841 said:It starts within 4 seconds of cranking, firing on a few cylinders then it catches up.
UPDATE: Finally got a check engine light, and pulled the codes.
Code 24: intake air temp
Code 31: afm
Code 52: knock sensor
Where should I start first?
Mk3TargaJames;2090842 said:A bad knock sensor will put the ECU into safe mode I'm 99.9999% sure.
As for codes 24 and 31, could be a bad AFM, but could also be a good amount of other stuff. I've also read in old threads where people never got their code 24/31 to go away.
