1987 supra 7mge Code 52 and 51
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Beliefs can impair judgment. For example believing you understand how a thing works, wiring is good, parts are OK because they're new, and knock has anything to do with setting this particular code. Until definitively proven otherwise they're just illusions in your head. Ooga-booga of the worst kind.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,238
Atlanta
Ive never personally seen a knock sensor go bad, but im sure it happens.
I missed in the reading: have you tested resistance between your signal wire and ground?
AKA- take the plug off each sensor, and probe the terminal inside against a good ground.
If there is continuity, that means that somewhere in your wiring, you made contact between the shielding wire and the signal wire. And by the way- exactly what type of wire did you use?
