1986.5 7mge -> 2jzge my very first build.
1986.5supra_kid
Rice? No its Corn (E85)
good news :well i got the r154 and lsd differential, bad news: the r154 has a short shifter housing welded to the original shifter housing and he lost the short shifter to the housing and the lsd ($40) has play in the pinion bearing.
So i need the r154 shifter housing w/ shifter and rebuild the differential... anyone rebuilt a these diffs? i have liiked over the tsrm and other forums but id like a little insight to the cost of a set of bearings and seals?
1986.5supra_kid
good news :well i got the r154 and lsd differential, bad news: the r154 has a short shifter housing welded:: angry :: to the original shifter housing and he lost the short shifter to the housing and the lsd ($40) has play in the pinion bearing.
So i need the r154 shifter housing w/ shifter and rebuild the differential... anyone rebuilt a these diffs? i have looked over the tsrm and other forums but id like a little insight to the cost of a set of bearings and seals?
UPDATE: STILL WAITING ON TITAN MOTOR SPORTS TO SEND BEARINGS!!!! i have cleaned the block for paint and i still have the head to clean and install new valve seals.
SupraKid
138
Santa Teresa, NM
I have the clutch that your looking at. If your goals are 450 hp im only guessing your torque numbers will be around that too. I would get beefier clutch then. That one is rated at 408 torque
IBoughtASupra
4,455
Queens, NY
Get a clutch rated higher than you need. When you will be hammering the car and launching, the heat will make it slip. Dragging a car always adds more stress, so give yourself some overhead.
1986.5supra_kid
well here is another option from DM. Aron insisted that this clutch would be good but ive never heard of them.
http://store.driftmotion.com/static/i-actionstage3clutchkitforr154.php
this is the next step up the act 3 stage
http://store.driftmotion.com/static/i-ts2-xtg6.php
this one seems way to expensive but its a bit over the goals of the motor
http://www.horsepowerfreaks.com/partdetails/HPF/Clutch/Clutch_Kits/Bronze_-_Supra_MK3_Turbo/2663
goals are 450hp to 500hp which i assume will work out to 500ft/lbs once at the 450hp mark?
1986.5supra_kid
1986.5supra_kid
IMG_20120316_163804.jpgIMG_20120316_170339.jpgIMG_20120316_180236.jpgIMG_20120316_185205.jpg
decided to go with the act hd pressure plate and the street disc
yesterday pulled the 7mge and w58 and damn was the exhaust a pain! there is this support that holds it close to the trans and the bolt end up breaking while trying to back it off. but oh well thats the oly think that broke. so annyone interested in a complete 7mge,w58,drive shaft and diff? lol hopefully this weekend the 2jz will go in. and i need a r154 retainer-housing and shifter. this r154 is missing those parts and my friend had sent one a month ago but it must have disappeared in the mail?! ugh
harley1985
117
killeen tx
sounds like your having fun bud, im so jealous! ill be starting my build in a few months here. im stucking with my 7m though. looking for about the same hp though. mounting a hugemungus A.R 83 :) should be interesting. ill be sure to take lots of pics
1986.5supra_kid
ill have pictures up soon, but the engine is in and it effing runs! the hx35w came yesterday and holy crap its big compared to the turbos ive seen on vr6 and tdi. so this friday ill have more on the swap. im looking for wastegate and bov. im open to ideas and im planing on using a ebay turbo manifold with a t4 to t3 adapter.
1986.5supra_kid
woohoo the 2jzge is in the supra and running!!! this weekend ill clean up the wires and get the trans bolted up and filled with oil and get the drive shaft in place. hoping to put a seal in the new 3.91 lsd diff and have it put in too. and i got my turbo also :DIMG_20120406_135150.jpgIMG_20120425_170142.jpgIMG_20120425_165937.jpg
Turbo_ryde
13
Edmonton
Looking pretty sweet! My JDM 2jz-gte just showed up! so looking forward to all the hard work and satisfaction that goes along with it as well!
