Personally, I ran a stant and had temp spike issues and it took forever to warm up. Bought one from a dealer and it warmed up faster and no more temp spikes.
Their not that expensive either...
Poodles;1435262 said:Personally, I ran a stant and had temp spike issues and it took forever to warm up. Bought one from a dealer and it warmed up faster and no more temp spikes.
Hmong_1G;1435403 said:I would go OEM. The OEM ones have a jiggle valve, rubber seal around the thermostat piston, properly tensioned spring. You pay for what you get. OEM has other different available temps rating.
jdub;1435486 said:Removing the jiggle valve is a very simple way to keep the system free of air...make sure it's at the 12 o'clock position in the housing.
jdub;1435486 said:A Stant SuperStat is as good or better than OEM...you want a 190 deg.
DBN;1435756 said:I use a 180* thermostat and my temp rests at 194*. Just my input but I would never use a 160*. I initially ran the 180* thermostat to be safe just in case something went wrong because my old one was stuck open when I got the car and I didn't know if it would overheat or not (bought it with the intention of it being a project). I also knew that until the temp was over 176* that the ECU would be in warm up enrichment mode.
dbsupra90;1435830 said:you can remove the jiggle valve with a pair of side cutters. if you dont fill your cutters with rtv, watch out because they go flying.
i usually buy my stuff from napa. their website kinda sucks tho. advance auto carries it too if you have that in your area.
195* 45869
180* 45868
edit: this is for the superstat
Fubar231;1435946 said:So using a 180degree tstat your coolant levels stay at around 195 degrees? I don't have a aftermarket water temp gauge but im workin on it... So 180 tstat would still allow the ecu to work properly?
