$150 bet for me to run 13.5, need advice
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Drop your rear tire pressure go with the 17s if those are your best option, up the front pressure. No one suggested dropping the front sway endlinks??? This requires some cautious practice as the car will handle completely different.
MA70R
68
canberra
also if you change your gear ratios that would make a massive improvement.
but it costs a bit. all i would be doing if i were you is playing around with tyre pressures maybe even use some good high performance tyres and just work on your reaction times,launches,shifts.and work on your optimum rpm range.
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
always shift at redline, already have 4.30 lsd rear end. Car is almost back 2gether, motor will be back in this weekend, beak in the headgasket, re trq, and work out all of the kinks
supranasty
Yo Daddy
Apr 12, 2005
374
jamaica ny
Make sure to put a good Clutch in the car . 6 puck minimum for Drag Radials. Stock will not hold up no matter what tranny. I had a 6 puck with my stock pressure plate then i went ACT. Stock Disk is fine for street radials but not drag radials. Also a THREE IN. Exhaust BIG DIFFRENCE. FYI Call me
queenskid926
Jul 27, 2007
1,112
New York City
c mon u showed kno me better than that, I have Act extreme pp and 6 puck. bic divorced downpipe, full 3" exhaust strait thru almost no bends all the way back. I listed some mods in my 1rst post but you can also check out my build thread.
http://www.supramania.com/forums/showthread.php?t=80505
supranasty
Yo Daddy
Apr 12, 2005
374
jamaica ny
Nice Rims... I guess im lazy to read page one on this thread . Extreme PP, im useing the heave duty. That sounds stiff . One Day i will make some POWER an try the Extreme .Are you useing the lex/550 mod with a safc ?
MA70R
68
canberra
ok it would be quick off the line with that diff ratio what tyes are you going to run? but the sounds of it you might get a bit of wheelspin in first and a churp in 2nd. post up some vids of your runs im interested to see how it goes.
Vacationtime247
74
Muncie, IN
How much lower of a rear end do you need? 4.33 LSD is pretty low. You'll be shifting gears so fast that it will actually slow you down unless you start in 2nd gear. I really wouldn't change the gears.
VT247
queenskid926
Jul 27, 2007
1,112
New York City
VT247
i never said anything about changing to a lower gear ratio, sette prolly thought that i had a factory turbo rear end and i just stated that i already have the 4.30's
supranasty
Yo Daddy
Apr 12, 2005
374
jamaica ny
honestabe;1302003 said:
ForcedTorque, supranasty was asking Jay who the guy was that ran 11.77, not saying that Jay ran 11.77
Honestabe Thanks. I did find out who the CT26 11.77 et was by. It was Bigdough666 , 3 time Modified Champion at Texas SupraNationals... . AUTO +NOS= A+ The Guy is Flying... I should of met him at the event... :love:
Dec 3, 2003
6,653
Canada
IJ.;1305926 said:
Maybe the $150 bet should have been for you to have it running for longer than 1 week ;)
lol....OUCH!
Get it running, no need to "break in gasket" if that's all you're replacing.
Will await results soon. :icon_bigg
Duane
queenskid926
Jul 27, 2007
1,112
New York City
Ok the car is back together and got her started last night
now I'm just waiting for 5 heat cycles to do a retorque, fix boost leaks and some other small things and then she will be headed to the track
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
niceee, when we hittin the track up? ive been practicing my launches, i think i can pull a decent time for a stock supra
gixxer750
2jzget comingsoon!
Mississippi
spray 150 and get the guy to bet you 500 you can't go faster than a 13.0
If you can drive and have/can borrow a kit, you can go probably pretty low 12s.
