15 PSI on stock inj and pump?
quapouh
Gear muncher/oil drinker
Jan 12, 2006
33
MIAMI, FL 33141
As for the 550 injectors ... what would you recommend for a direct drop in injector ... so the clips on the original harness would fit? ...
- as for FPR i guess the only recommended one is aeromotive one ... it's quite expensive but i guess it;s the only way to go if you want to do it right? any comments?
- as for exhaust system ... well since stock elbow got only a bung for narrow band O2 sensor and I'm planning to go BIC DDP and full 3" straight anyways ... I guess I'll do everything right from a start than ruin something with being cheap
-as for wideband ... what would you recomend ... something that would
get along nicey with A/F electronics?
- as for electronics - wow thats a "river" topic ... to many diferent ones on the market ... suggestions ...
as for IC - I'm getting Bigaarons unit with stock iC pipes [before I can afford hardpipes]
Basically I'm looking for 350-400 HP setup for a daily driven car that will be reliable [as supra cn be when done right]
All comments welcome
Mike
drjonez
the motor city
www.4cefed.com
no. the only "drop-in" ones are high impedance. stock are low impedance. the drivers are meant for low impedance.
yup, do it right or do it twice.
eh?
any WB will do....some are better than others. i sell innovate WB products...
depends on your goals, decide on WHERE you want to be and then decide HOW to get there. i sell the MAFT line of products...
stock 20 yr old IC hoses suck.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
now they are not technically new, but venoms are direct drop in. if you search here youll see good and bad stuff about them.
yup, listen to the doc, i would change the ic pipes before the ic, if your low on cash.
quapouh
Jan 12, 2006
33
MIAMI, FL 33141
Now ... I hear about Low/ high impedance type ... yet it was said that you can adapt high impedance do our supra by removing the resistor ... Is it commonly done or bast shot would be for low impedance with clips and splicing the harness with new clips?
drjonez
the motor city
www.4cefed.com
sure you can slap in high imp. injectors and pull the resistor....but why? do it right the first time....if you're afraid of cutting and soldering wires, you shouldn't be attempting to "modify" your car...
SublimeSupra
Dreams of the Touge
Jan 17, 2006
170
Largo,Fl
Im confused now i thought turbo injectors were high and n/a were low?I think i remeber reading a huge thing on injectors on here last month.
drjonez
the motor city
www.4cefed.com
you are confused:
all 7M-GTEs have low imp. inj.
<'88 GEs have low imp. inj.
'90+ GEs have high imp. inj.
figgie
Twin Cities, Minnesot-ah
Aeromotive is not expensive. Actually one of the cheapest out there.
Expensive is the WELDON 2040 fuel pressure regulaotr ;)
quapouh
Jan 12, 2006
33
MIAMI, FL 33141
Since I have managed to slap new engine on that baby I dont thing i'll have a problem with that :D but thanx for concern Dr oh good Doctor :D ... thanx for all the answers guys ... Time for my morning expresso :p
MKIIINA
Destroyer of Turbos
Plano, TX
someone show me a failed toyota fuel pump. im so tired of people basing their guesses on it being old. i ran the lex afm and 550s off the charts rich with the stock pump and regulator on an sp61gt turbo up to 18 psi daily driven on pump gas. someone show me some concrete proof of a failed pump killing a motor because it was old and not some other reason (crap tune, low octane, old tired motor etc)
lagged
1991 1JZ
new rochelle
my pump failed. it wasnt flowing enough fuel for 10 pounds of boost. i blew 2 head gaskets because of it.
its not a guess, its CHEAP insurance.
replace your fuel pump FIRST.
this was on a brand spanking new rebuild too i might add.
i replaced the injectors with NEW 550s, AFPR and still detonated.
after i replaced the fuel pump (and 2nd blown head gasket..) EGTs came down and detonation stopped.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
On the subject of the stock fuel system, and safety, I already have a walbro pump, and new filter, But I'm getting low on cash from lots of unexpected surprises, and doubt i'll be able to get a AFPR setup by the time i'm ready to drop in the engine. Would it be ok to run the walbro pump on the stock FPR & lines? Will I run rich?
