14.5 @ 95mph
SupraDreamPDR
Boost-a-holic!!
Feb 3, 2006
1,140
Springfield, OH.
i did 14.7 at 95.9 mph with K&N, DDP, testpipe, no cat. back, XTD Clutch/FW and all season tires. i was running with a boost leak also and the beginnings of a BHG.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
ive been reading everyones comments on their times with their own mods. i will have my car back in about a month and i was wondering if anyone could let me have somewhat of an idea of what kind of numbers i should be seeing. i will have:
k&n intake
3.5 dp
2.5 catback
boost @10 lbs
aftermarket FMIC w/ 2.5 ss piping
walbro 255 pump
ngk plugs and wires
no egr
no ac
new oem clutch
stock tires
any ideas on hp or et????????
Derek1224
2 Turbos, 1JZ, No Equal
Nov 25, 2006
50
Abbotsford, BC, Canada
k&n intake
3.5 dp
2.5 catback
boost @10 lbs
walbro 255 pump
ngk plugs and wires
no egr
no ac
new oem clutch
stock tires
Low 14's maybe if you can hook up with those street tires.
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
k&n intake
3.5 dp
2.5 catback
boost @10 lbs
walbro 255 pump
ngk plugs and wires
no egr
no ac
new oem clutch
stock tires
3.5" Downpipe and 2.5" Catback? Ouch.
Given you have a reasonable launch, 14.2 to 14-5 should be what you'd be looking at.
As far as horsepower goes, probably 235-240rwhp.
-Jeff
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
i know, i bought the car with the 2.5 catback already on it and had already purchased the downpipe for the swap, so now i have to save up some money and complete the 3.5 turbo back.
Derek1224
Nov 25, 2006
50
You can get it done relatively cheap at a local muffler shop. I'm sure one could make you a catback for about 200 bucks if you supply the muffler.
Derek1224
Nov 25, 2006
50
the beauty of running open downpipe is after you're done at the drag strip, just bolt the cat and exhaust back up and you're legal again. :naughty: :biglaugh:
Mosupra9
55
Tucson
WTF???? im readin all this and all these MKIII's are basically stock....i had a BONE stock MKIII turbo AUTO....wiit just exhaust done to it and my best time was 16.1......i live in ARIZONA.....but it feeels faster if i were to race u from a rollinng start..
Derek1224
Nov 25, 2006
50
Something to do with your gearing maybe? How was your launch and 60ft times on the 16 second run?
tissimo
Stock is boring :(
Melbourne, FL
I've done 14.3 at 95 stock with shims (10 psi falling to 7 psi)
Mosupra9 what was your trap speed? that'll tell you more if you car is making the power over the 1/4 mile time..
supradavenz
LOL HIES!
Apr 1, 2006
159
AUCKLAND, New Zealand
Maybe i just can't drag race.. but.. my best time was a 15 flat mostly stock standard asides 3" exhaust w/2 resignators and turbo muffler and 3" chrome elbow and a k&n 6" adapter air filter running around 10psi boost with a fuel controller. oh and a BOV.. traction was a bit of an issue.. running 255/40r17 rear's and 1st gear was almost a waste of time. any idea's about that guys? tips on what rpm to launch at (im running w58 box btw)
