13.9 sec mkiii lexus afm with 440 engine did not blow???
supraman16
SUPRASAVER
Jul 23, 2006
68
Atlanta
This maybe the only case like this. Let me know if anyone has any similar.
I hve a 89 mkiii turbo. Stock ct-26 hks metal head gasket arp head bolts
torqued to 75. Lexus afm for fuel cut without 550 injectors. still have 440.
3 1/2 INCH DOWN PIPE with no cat full 3 1/2 inch exhaust. apexi
cold air blitz blow off valve. manual boost controller turned boost to 14.5
psi. Did not expierence spark knock or pinging ran car hard shifted at 6k rpms
ran 13.96 at 102 mph at atlanta speedway sat july 22. Most say i will blow the engine without 550 injectors. I must have been lucky.
shaeff
Kurt is FTMFW x2!!!!
10
Around
if a video isn't posted, this will be moved to the general section...
-shaeff
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
sounds pretty risky to me, especially if you didnt tune, use 550's, or upgraded fuel delivery. actually i change my accusation from risky to stupid. Even if you didnt "blow the engine" you could be doing some damage in there. Probably softening up the top of the pistons. Keep it up and your pistons will be see thru :). Oh and as for that metal headgasket, dont count on it lasting long with that setup.
and post the vid.
Dec 3, 2003
6,653
Canada
I have run stock injectors with stock AFm but with a FCD and stock 440's and ran 13.0@113.65 didn't blow up ;)
My buddy Tom has DDP, but 57 trim, exhaust, Lexus AFM but 440's, 13 PSI IIRC and I ran his car to a 13.3@ 107 :) He had less mods than mine and was heavier to!
Duane
Nice run by the way.
antman
632
TN
do u have an EGT gauge or a wideband?
wait....if theres no video, maybe it never happened.
supraman16
SUPRASAVER
Jul 23, 2006
68
Atlanta
the guys at the shop shot the vid it will be ready soon. iI do how ever have the venom 550's on the way. gonna upgrade the pump too. it's a daily driver drove it hard only that 1st time. stupid move oh yes i know
edit: don't type in all caps please, it's considered shouting on the internet
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
I noticed you didn't specifically quote anyone when you made this post!:icon_razz So who are you calling a liar?! (If you are???):icon_conf
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
91T, I think he was just being sarcastic...
However, just to be safe, and this goes to the thread starter, I wouldnt push it TOO hard until you get more fuel...
JohnRardin
JDM 7MGTE
Apr 4, 2006
110
Radford, VA
Believe it or not, contrary to popular belief, using a lexus AFM on a stock fuel system doesnt hurt the engine whatsoever. I ran my 89' turbo with nothing but 3" exhaust, cold air, and the lexus AFM for over a year and saw nothing but good results. The engine has 160000 miles now and doesnt show any sign that its going to blow up. What most people dont understand is that the ECU shouldnt really allow it to run extremely lean; it just doesnt use as much air as it would if you had the fuel to keep up.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
^Did you monitor your Vf's, Did you run a wideband? Do you know if your ECU was pulling timing?
Its more than just running it and everything being "Ok".
Anh
31
London
OK...what about those Supras that produce sub 10:1 a/f fueling with standard injectors , standard fuel pump, with standard fuel pressure and a standard AFM at boost levels before fuel cut kicks in?
What about the 80-90% injector duty cycles reported with S-AFCII's and E-manage on the injectors at WOT near 6000 rpm?
Do you really need 550cc when Supras with the stock turbo run this rich as it is?
