12 volts and Walbro fuel pumps
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
For those of you running walbro fuel pumps MAKE SURE YOU DO THE 12V MOD, and RUN A 12 VOLT RELAY FOR EACH PUMP USED! I installed my dual fuel pumps and tested both of them in the tank before installing the tank. After making sure they both worked I buttoned everything up, and then I tested the pressure of each pump separately. I found out that the pumps were running less stable when run directly off of the stack setup.The pressure would fluctuate as I tried to set fuel pressure over 35 psi. When I wired every thing to the relay, and ran a wire from the relay to the battery to power the pumps the pressure became stable, and I had no problem making 35+ psi. So if you are runnung a walbro fuel pump, and are not doing the 12 volt mod you may eventuallly ruin the pump, or worse lean out at high hp and blow your motor. When I did this with one pump in the car, and when the gauge fluctuated I thought that the gauge was going bad. When dynoing the guy running the dyno told me he thought the pump was not supplying enough fuel and was weak. I felt this was wrong since the pump was a year old and can support at least 500 HP. Now I know that the pump wasnt getting enough voltage to keep up with the powere being made.
lagged
1991 1JZ
new rochelle
hmmm. i must be missing something.
with the stock setup itll kick it over to 12 volts in open loop, and as far as i knew you wouldnt ruin a walbro by running it at 9v.
Justin
Speakers?
Spokane, Wa
I think this is one of the most debated about topics on the boards. The Walbros specs say it'll work just find at 9V.
When the 88T was still around there was a nasty hesitation from idle if I was to floor it... I bypassed the resistor and it went away 100%
That's my input into the issue :)
QWIKSTRIKE
Apr 3, 2005
1,172
Maybe, maybe not but the one I had in the tank didnt run half as good as the new ones after a year, and pumped less fuel at the same setting by 5 psi.
lagged
1991 1JZ
new rochelle
i recall seeing a chart some where showing the rate of flow at different voltages.
ah i dunno. i bypassed the resistor anyway a while ago.
lagged
1991 1JZ
new rochelle
maybe if you hear the sound change and fluctuate with an electrical load on the system its bad, but every walbro pump brand new ive seen installed, 2 in friends cars and one in mine, also make the same sound while they are running.
hearing a walbro dosnt mean its bad, that is normal.
the only way to test if it is bad is to see how much current it is pulling, or to measure how much fuel it is flowing.
if it makes a significantly different sound than what is normal, then something might be wrong and you should test it.
again, just cause you can hear it does NOT mean it is bad.
3 out of 3, brand new pumps all have made the same sound while running, and none of them have gone bad.
lagged
1991 1JZ
new rochelle
jtamulis said:
a LOUD walbro is bad. A normal one is not bad. If its really really loud it will
not pump high pressure and volume.
Jeff
id tend to agree.
i just wanted to clarify for those who might have been mislead, if you can hear the fuel pump, it does NOT necessarily mean it is bad.
cruzian7m
virgin islands native
Jul 31, 2005
217
phila,pa
would i need to perform the 12 volt mod with the mr2 alternator upgrade and a standalone? I've got the walboro pump and a haltech standalone which controls my fuel pump. (p.s.- the car is down for the winter).
QWIKSTRIKE
Apr 3, 2005
1,172
Basicly this has nothing to the alternator, andlots todowith the fuel pressure regulator!
