-10AN to -6AN Y Splitter?
dejacky
175
"taxus"
I've seen the Y-splitter adapters that go from -10AN to dual -8AN, but does anyone know where I can find a Y splittter adapter than goes from -10 to dual -6 an? It's for a fuel system that uses ethanol and gasoline, yet I've searched for several days trying to find such a piece :aigo:.
supraman502
not lazy, just dont care
Apr 8, 2005
326
louisville, KY
dejacky;1422976 said:
I've seen the Y-splitter adapters that go from -10AN to dual -8AN, but does anyone know where I can find a Y splittter adapter than goes from -10 to dual -6 an? It's for a fuel system that will be using both ethanol and gasoline and I've been searching for days to no avail :aigo:.
I've got one I'll sell you
http://www.supramania.com/forums/showthread.php?t=99318
I'll take 25 shipped for just the splitter
toyotanos
What will we break today?
2,842
Coon Rapids, MN
It is. I think you're supposed to use the distribution block (link #1) and then thread the adapter (link #2) into it.
Cz.
CAR > FAMILY
Seattle, WA
That's why you get the adapter piece...
You screw that into the Y so that it becomes a 10AN in and two 6AN outs.
dejacky
175
"taxus"
I'm just worried that NPT won't seal as well compared to AN thread fittings. This is fuel afterall, so I want it to be safe as well...thanks for the recommendations, please keep em coming :).
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
if you assemble it correctly, it will not leak.
search on summit, there are other splitters, i chose one that works and is cheap.
supraman502
Apr 8, 2005
326
louisville, KY
everything needed
Cz.
CAR > FAMILY
Seattle, WA
Use teflon tape and it will be fine.
dejacky
175
"taxus"
I thought I found one on summit called Mr Gasket SR106, but the picture is WRONG:
Instead, I received a flare reducer from -10 to -6an
Does anyone know where I can find a Tee fitting like the above picture that converts a single -10an size to dual -6an outputs?
dejacky
175
"taxus"
I just want one fitting that converts a single 10an fuel line to dual 6an outputs. Tee or Y does not matter to me.
