100ft lbs
Status
Not open for further replies.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Hmm, I didn't know about the cycling deal. I only thought you were suppost the torque down to a certain amount first for all bolts, then torque down tighter again for all, then do the final torquing.
You are indeed the man John! ;)
Ninja edit: So do you just back off a stud/bolt like 1/4 to 1/2 a turn then torque to the next value?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Awwh thanks guys!
I see a lot of problems pop up on this site and I question why it's done this way or that way, so I try to figure it out ;) I have mechanical engineering from long ago in my background and been a gear head since I was a teenager. Since cars are getting so blasted complicated, gotta do something to keep up!
You actually go through the entire TSRM torque sequence to spec...I like to use 15 ft/lb increments (but that's technique). Then you back all the bolts/studs off and do it again. I did mine 3 times...then I did a re-torque after the motor went through 5-6 heat cycles...again, technique.
JDM 1JZ
I hate Tires
Aug 31, 2005
301
Cherry Hill, New Jersey
so do, lets say 15ft lb - 20ft lb incraments and you get to 81 or whatever you desire, and go thorugh the loosen sequence, and start over and then start over and then done, then 5-6 heat cycles(which i knew) and check?
jdub
Feb 10, 2006
10,730
Valley of the Sun
One other thing...don't forget to apply RTV to the top of the aluminum front plate. The precise location is in the TRSM. This has nothing to do with the HG seal, but everything to do with preventing a nasty oil leak down the front of your motor ;)
JDM 1JZ
I hate Tires
Aug 31, 2005
301
kk will do, hopefully it holds up like my last, my last was on 21lbs on a t4 beating on it for 2 years and some time.... dun dun dun, my other motors almost ready to go in anyway, fully machined and mhg ready, i'll probley put it in when this ones completely done
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
jdub said:
Awwh thanks guys!
Ahhh, I see the light of your reasoning now. I will use this "dub-nique" when I perform the task of rebuilding the supra ;).
empera
Authorized Vendor
Philly.
CryoSlash said:
as a side note, does anyone know where ot get soem moly lube? my set from bobiseverywhere came with about half of it used (his studs were used and i etched for used because they have gone throuh heat cycles)
i got mine from ARP...called them up and said "I Need some Lube!" bam..got some some lube ;)
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
^Lol, they probably thought you were needing some KY jelly or something.
BTW: did you get a big can of (moly I'm guessing?) lube, or the smaller tube? How much did ARP charge you?
Status
