Due to the fact that SF isn't accepting new members and my 1/2 NA-T thread got wiped out by the hacker I am just going to post everything on SM since I have been getting tons of questions about it. I only posted my posts from the thread so the text might not make too much sense. Later.
Another Thing. TUNING make sure your car is tuned properly, thought I had all the bugs worked out but ended up going lean and cracked a piston through the ringlands. Also make sure you do a compression and leakdown test before you start this conversion. If your engine isn't up to snuff(ie low compression, oil leaks, other bad shit) do not do this conversion. Spend the money and rebuild...do it right. BTW make sure you will have a constant flow of cash money because you will need it. Later.
