1.0 mm HG
crosupra
21
Croatia
Hi, i'm changing HG on my N/A so i'm thinking about 1.0mm hg to raise my compresion.
So, can you tell me what compression ratio should i expected, and what power gain?
can that way of raising compression do some damage my engine?
Tnx, and sorry for crappy english
Ma70.Ent
1,871
NJ
drjonez said:
stock HG thickness squished = 1.2mm.
there is a TON of stuff you can do to the engine, most importantly being upping compression ratio. shaving the head to up CR isn't the best idea as the combustion chamber gets all wacky then. unfortunately, with the amount of $$ you'll spend on custom headwork and pistons, you could have turbo'd the car and been making 2X the power (not trying to start a war, just giving facts.).
Good thing I had that saved. Gotta save useful stuff like this :D
crosupra
21
Croatia
Kai said:
If you raise the compression ratio - you should think about running higher octane fuel like 98 RON to minimise the likelyhood of detonation.
high octane fuel isn't problem (95, 98 and 100)
