Hello,
I know that many of you have done this before and I have searched for the info I'm looking for but failed to do so.
First of all, I'll be using Swoosh 60mm SM68 gauges and I'll replace the boost, oil pressure and water temp gauges in the stock cluster.
I have done some trimming for one of the gauges on the black "frame" so that it sits flush with the frame.
The problem now is that the clear plastic cover doesnt fit, my gauge sticks out to much.
So now I have two choices, cut a hole in the clear plastic for each gauge or trim the black frame some more.
But if I trim the black frame some more it will be weak.
What I tried searching for was pictures of how you trimmed the black frame piece.
So, any idea?
Thanks
/Marcus
So, any idea?
Thanks
/Marcus
