Question on Mystery vacuum switch under intake
SupraMan1987
258
Hickory area, NC
What is the purpose of the front vacuum switch under the intake manifold that has 2 vacuum connections on it? I know the other switch in the rear is for EGR, but what is the front one for? Seems to me like I remember seeing it had something to do with the fuel system. Any help would be appreciated, thanks guys.
thevork
ShoarmaTeam Member
SupraMan1987;1438189 said:
Is it necessary? I've got an AFPR and am planning on a Walbro.
your afpr will need a vacuum feed to raise FP by 1:1 (every extra psi in your manifold should equal one extra psi of fuel pressure).
edit:
Not to be an ass or something but when you don't know the purpose of a VSV for fuel, please start reading every bit of information about this subject before upgrading with a walbro and afpr.
If you don't, you'll kill your engine because you don't really know what your doing.
My 2 cents.
SupraMan1987
258
Hickory area, NC
I was questioning Toyotas purpose of putting it there. I know perfectly well how to install a Walbro, and an AFPR. I just didn't know if it was something emissions related with the fuel system, or if it was an actual necessary component. What exactly does it do? The switch that is. Just signal for higher voltage to the fuel pump at start up?
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,776
Long Island, Ny
It acts with the same principal as the cold start injector. The fpr rises 1:1 with boost and falls 1:1 with vac. The valve keeps vacuume from the fpr for start up so it has the fuel required to start properly/smoothly.
I havnt run one since I first pulled my motor 3 years ago and never had an issue in my experiace.
Possible side effects of removing are longer crank time and/or stumble on startup.
tedjerz
10
New jersey
I disabled mine also. No bad side effects yet. Sarts and runs hard when its cold out, but smooths right out when the engine warms up.
mkIIIman089
Ohio
^If it doesn't run right it isn't the fault of any startup equipment (CSI or the FP up VSV). Both are only operational with the key in "start" AFAIK.
