Need help with 7mgte electrical issues, my 7mgte randomly runs rich burying the wideband to where it just shows dashes, it wont idle without you giving it light throttle and when you give it more then light throttle itll shut off, not like bad maf at around 2500rpm, it's around 1100ish maybe a little more, it just tries to die like you turn the key off, but if you quickly let off the petal it wont completely stall. If you pull the afm signal wire loose it'll run better, it runs like it normally would without the afm hooked up which is better then when its acting up like this, i men its so bad you cant drive over 10-15mph! I have tried different known working afms with no change whatsoever, disconnect tps, only makes a difference in a slight idle change, im at a loss, itll work great for weeks then slowly start acting up worse and worse til its undriveable, and other times itll just randomly instantly go to the point of undriveability.
