is e-manage a good choice
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
Is E-manage ultimate a good choice for fuel managment i want to run 15 pounds of boost without hitting fuel cut and i dont want to use full stand alone any help would be ausome thanks
drjonez
the motor city
www.4cefed.com
on paper, the EMU appears to be fantastic....the problem is no one has really played with it on the 7M. it shouldn't be to hard, just use the settings used to make the blue eman work.
it may be overkill for such reasonable goals, a SAFC would do the same thing and probably be cheaper....
Bondango
Supra Specialists Ireland
We install the EMB mainly on 2jz-gte's. The only problem we have ever came accross is Ignition timing on UK spec 2jzgte's. On J-Spec 2jzgte's it works flawlessly (though no monitoring) but on UK cars it falls flat on its face when the ignition harness is used. I also have yet to hear of anyone successfully using timing control of the EMB on a USDM 2jzgte. I know Mohd's site has a great install, but wther the Ignition timing end of things worked is a mystery.
For the 7M its MAFT all the way, quite easily the best BFB unit on the market.
Marty
Zazzn
l33t M0derat0r (On some other forum) n00blet here
Toronto/SF Bay area
I had it working fine on my 1jz. and it will be on my JDM 2jz for a bit till i swithc to my aem.
I have experiance with emanage on many 7m cars, it's worked like a charm.
MAFT t is a better option if you can ditch the AFM but emanage is very easy to learn and configure.
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
good to hear, ive got a jap 2j, so from the sounds of things it shouldnt be to hard to get my car up and running
Bondango
Let me know when your ready to install and il help you out with the correct jspec info (you can still use Mohds Site as a guide) and if your running bigger injectors etc etc i can sort you out with a basemap to get you going.
